Different result when converting from Color Index (ACI) to RGB on RTX and Quadro graphic card
m.nguyenLFD44
Observer Observer
m.nguyenLFD44
Observer
Observer
I have 1 DWG file whereas need to change layer color from AutoCAD Color Index to RGB.
Spot check on some colors on large palette and second palette, ACI 60, 181 -->the result is the same on both RTX and Quadro graphic card.
But, there's issue with third palette from color 250 to 254.
Index                      RTX RGB                        Quadro RGB
250                             0, 0, 0                             51, 51, 51
251                        101, 101, 101                        91, 91, 91
252                        102, 102, 102                      132, 132, 132
253                        153, 153, 153                      173, 173, 173
254                        204, 204, 204                     214, 214, 214
Does anybody know the reason? and is there any color has the same issue as listed?
Thank you all.
cadffm
Your Title looks great and interesting, but i guess you are on the wrong track!
I guess you "tested" this with different background colors, or not?
In Color dialog and also the color of your objects on monitor,
the rgb color/value is depending of the background-color.
For example: 33,40,48 vs color black OPTIONS, Display [color]
>>and is there any color has the same issue as listed?"
depend on your backgroundcolor
Q:If you need to change ALL colors, use a program which can do that!
You will find some "ACI2RGB" tools and the result should be good enough.
(I can talk about some more thoughts, but i am out at this point, HTH)
Sebastian
m.nguyenLFD44
Observer
Observer
Oh, dear
I tested on different computer and dismissed the background color.
You gave me a perfect answer. Thank you very much.
