Differences
Differences
Differences
am thinking of purchasing either Autocad 2018 or Autocad Mechanical 2018. Is the only difference its mechanical componentry/library? But more importantly do both have the same 3D drawing capability?
Phil
BeKirra
The explanation in short.
Both of AutoCAD & AutoCAD Mechanical can do 3d modelling.
AutoCAD 2018 is a plain version in AutoCAD series.
AutoCAD Mechanical 2018 is a vertical version which is built on top of AutoCAD and not only adds Mechanical library but also has functions for mechanical engineering design.
Here is links to Autodesk home.
AutoCAD Products
https://www.autodesk.com/products
AutoCAD (Plain)
https://www.autodesk.com/products/autocad/overview
AutoCAD Mechanical
https://www.autodesk.com/products/autocad-mechanical/overview
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
