Diesel Expressions for file path
ben.williamsMPBQ3
ben.williamsMPBQ3
Hi all!,
I would like to be able to access file names that are at the end of a file path, however one file name in the middle of the path changes in length. e.g.
2019/ 123456 'Name length changes'/Drawings/Mechanical/Preliminary
I can get Diesel to get '2019' and '123456' with no problem as the character lengths never change. Is there a way Diesel can count backwards? As the folder names 'Mechanical' & 'Preliminary' don't change in character length.
So if there was a way for Diesel to just grab the last two folders, count the folder string characters backwards there would be no change in character length.
Any help would be greatly appreciated.
ВeekeeCZ
DIESEL has very limited functionality. Look HERE at the list of all functions available.
Unless you're on LT rather move to LISP.
ben.williamsMPBQ3
Unfortunately I don't quite understand the code, I have been able to manipulate the numbers of characters on
existing codes to get the desired folder name from a path.
One code I was using was able to delete the last character of a string, which has made me think can a code count the characters in a file path backwards. If it can, I can get the file names of the last two folders and the fact that a previous folder name changes in length would not affect the last two folder names.
Am I making any sense? :s
