Diameter dimension with arrows inside circle and text outside
gmaniatisW9U6H
Message 1 of 8
gmaniatisW9U6H
I cannot figure out how to set the options so the dimension appears like it is in the picture but without the extra line on the outside of the circle (area circled in the picture).
This has to be a very simple setting or combination of settings, but I just cannot do it.
Replies (7)
Message 2 of 8
apjones
Going from memory, I think the variable "dimexe" needs to be set to "0".
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 8
apjones
...or it may be "DIMDLE".
Pete
Message 4 of 8
gmaniatisW9U6H
@apjones, sadly neither of those options work. The closest I can get is by changing the "Text movement" field in the Fit category in the properties for Diametric Dimension. When I set it to "move text, no leader" the line outside the circle goes away, but the line from the circle to my dimension goes away also.
Message 5 of 8
paullimapa
This is the DDIM setting you probably have now:
This is the DDIM setting you should try:
Paul Li
IT Specialist
@The Office
Message 6 of 8
pendean
Community Legend
Community Legend
@paullimapa wrote:
...This is the DDIM setting....
DIMSTYLE command
Message 7 of 8
gmaniatisW9U6H
I knew it had to be something simple.
Thank you, Paul.
Message 8 of 8
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
