Hey all, I'm banging my head against the wall over here after a long day of drafting. I have a 19' diagonal line that I am trying to make in a section view. For this project, it doesn't matter what the angle is as long as the line starts at (for example) 2' high and ends at a specific height and is a fixed length of 19'. This is a ramp with a stud wall configuration and a 3/4" plywood deck that tapers down to the plywood hitting ground level. The surface of the ramp needs to be 19' regardless of the angle and total flat surface covered. I'm having a lot of trouble getting this drawn where the top surface of the plywood can start at 2' and then angle down and have the bottom surface of the plywood touch the ground. Is there a rotation command that would help with this? I've tried drafting a lot of construction lines to figure this out but I'm at the point where I'm hitting a wall. Any help would be greatly appreciated.
