DGN file import issue
darri
darri
I received DGN files and when I import them images are missing.  According to the person sending me the DGN files, there are external references within the DGN file.  How do I keep the external references from being lost during the import?
0 Me gusta
Responder
353 Vistas
5 Respuestas
Respuestas (5)
hencoop
Did they send you the images files (and their DGN files if they are in separate DGN files) along with the DGN file you are importing?
You need them too.
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
0 Me gusta
s.borello
Make sure they send you the missing files.
0 Me gusta
darri
They sent me a ton  of DGN files in a zip folder.  I extracted all the files and saved them on my computer. But I only need 4 of the DGN files to import.  I kept all the files together.  But when I import them, images are missing
0 Me gusta
hencoop
They may have full paths that include shares and folders that you do not have.
Usually, AutoCAD reports the "missing" reference files to your text screen.
If the missing files are put in your current drawing folder they should be found regardless of their paths.
The only other alternative I know of is to create the shares and folder structure on your system and extract the files restoring the original folder structure exactly.
0 Me gusta
hencoop
Also, if the image names are listed in the CLASSICIMAGE window, either ask them to send you those image files or if you have them make sure they are in the current drawing folder and then reset their path to just be their name.  That should let AutoCAD find them.
0 Me gusta
