DESING CENTER and Copy/Paste Elements
No aplicable
I use to work with DESING CENTER to update my blocks in differents DWG.
After doing this, when I try to COPY/PASTE any elment between two differents DWG, Autocad takes a long, long  time to COPY the original elements.
Dos anyone have the same problem?
0 Me gusta
Responder
Soluciones aceptadas (1)
500 Vistas
3 Respuestas
Respuestas (3)
imadHabash
Solución aceptada
Hi and Welcome to AutoDesk Forum,
there is a lot of reasons cause this problem.herewith AKN  article mention some of solutions that it may help.
Imad Habash
No aplicable
Ok, Thank you
I normally can copy elements from a DWG to another, and I have no problems of memory, but that particularly happens after I open the Desing Center and update any block so I can imagine that Desing Center have any problem managing the memory.
0 Me gusta
No aplicable
Hello, I've my own solution and apparently that works:
_Open the Design center window
_Select your DWG
_Click on the blocks tab
_Do your operations, like Redefine a block.
_When you finish, click on another tab of the DWG, like dimstyle for example.
Apparently, if you less the Desing center on the blocks tab, Autocad needs a lot of memory to run.
Thank you.
0 Me gusta
