Design Suite Premium 2015 Graphics card and Install on Windows 10
No aplicable
Firstly, thank you for helping me on this as I have no real clue anymore on what I should get my client.
On the AutoCAD.com site to look up certified graphics cards, the design suite only goes to 2014,but my client has 2015.
Would the Quadro M4000 8GB work OK under an i7,  16GB system running Windows 10 Pro.
Has anyone got any recommendations on a good graphics card.
0 Me gusta
Responder
Soluciones aceptadas (2)
291 Vistas
3 Respuestas
Respuestas (3)
ennujozlagam
Solución aceptada
@Anonymoushello, it will still works on autocad 2015 windows 10, you also can check it <<click HERE>>.
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I feel that configuration will likely work just fine for 2015 products. However, if the client is likely to later to use more current product then you might consider looking at recommendations/certified hardware for those products.  Since the Suites are no longer available (they are now collections) you can look up hardware product by product on that page to see what might make the most sense.
BTW, I have started reaching out internally to see if we can't get that page updated for Collections.
Please make sure that your client installs hotfixes and service pack for the 2015 product to run properly on Windows 10.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
