Design Center TREE path not staying set
brianwclayton1969
Message 1 of 8
brianwclayton1969
Good afternoon AutoCAD users, I'm having a issues with the Design Center TREE path not staying set once I opening it and scroll down in the left side Folders list - TREE and then close out AutoCAD and reopen it the TREE Path does hold.
See screen shot. This is how it should stay, but it closes and I have to reopen the path every time.
Thanks for any assistance
Replies (7)
Message 2 of 8
cadffm
if you read the help[F1] about Designcenter, you will find how to set the home folder and favorites,
EDITED I missunderstood - but not a kind of "remember folder"
"rememberfolder" is default and you can't change it.
https://help.autodesk.com/view/ACD/2024/ENU/?caas=caas/sfdcarticles/sfdcarticles/System-Variable-to-...
Sebastian
Message 3 of 8
pendean
Community Legend
Community Legend
I am unable to replicate your issue here: are you running the updated version of AutoCAD2023 as I am (see below)
Message 4 of 8
cadffm
because of predeans post, I reread your post and I had to edit my reply.
My new answer: It should stay where you left the DC
If it doesn't work:
Happens every Acad-restart, or just every PC-restart?
If you add a new conversion setup (Command DWGCONVERT),
is it gone after a restart too?
Sebastian
Message 5 of 8
brianwclayton1969
It happens in every AutoCAD restart.
Message 6 of 8
cadffm
And my other question?
This test with DWGCONVERT is to check the question: Does your Acad remember other setting in the same area of your registry or not.
(Ae familiar with the registry? If so, I can explain more details, but run the test first)
Sebastian
Message 7 of 8
brianwclayton1969
I typed DWGCONVERT and there wasn't anything the box, so AutoCAD doesn't remember anything. I think my issue maybe the version NOT being updated. Mine states AutoCAD 2023 not AutoCAD 2023.1.4
Message 8 of 8
pendean
Community Legend
Community Legend
@brianwclayton1969 wrote:
...Mine states AutoCAD 2023 not AutoCAD 2023.1.4
Then you need to get that update ASAP, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
