Design Center not visible
paul.wood
paul.wood
Don't seem to be able to move the "Design Center" window after it pops up.
Usually I can grab with the mouse.
user181
Hi @paul.wood,   If you click inside the design center window and press the ALT + SPACE BAR you should get a menu. Select M for move and then use the arrow keys on the keyboard to start moving the window.
paul.wood
TO:
User 181
Thanks for your post.
What you said is right.
But, since I had two monitors going, I couldn’t get that to work.
What I did is shut down the extra monitor, then got the Design Center back in the main computer window.
Now Design Center is back, and all is well.
Thanks for your help.
…Paul Wood
