Announcements
Deselection by Shift+Click not working
JCCDeAngelisIron
JCCDeAngelisIron
Used to be able to shift-left click to deselect an object from a selection group.
Most solutions are for Raster, Civil3D, or Map3D but I am only using vanilla AutoCAD so none of these work.
chriscowgill7373
What does it do when you shift click? do you have PICKADD set to 1 or 2?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
JCCDeAngelisIron
Currently when shift-clicking to deselect I get:
Select objects: <Cycle on>  <Cycle off>1 found (1 duplicate), 8 total
PICKADD is set to 2
chriscowgill7373
are you holding the space bar when selecting the object?  That is the only way I can pull that kind of output
