Depth observed in 2D DWG file while testing with Hoops Communicator
We are trying to use 2D DWG files in Hoops Communicator (web based toolkit). We convert the DWG file to Hoops communicator native format (stream cache(sc/scz)). After conversion, we are observing a depth for drawing. All the entities are placed not placed in single place. The group of entities are placed in different plane. We are trying to use this 2d DWG file in federation with 3D model. In this context, we have access to navigation/orientation of model, so we can observe that all entities of drawing are not placed in single plane.
We are already communicating with Hoops Support for this query. We would like to know AutoCAD experts, whether this is result of any metadata/properties in DWG file. Is there something as part of DWG file that may result in placing entities in different plane?
Please find attachment for DWG (3D +2D) file.
Thanks.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I do not see any hidden objects in the drawing on the AutoCAD side, no objects off the primary plane, or any metadata/3rd party.
 I would guess it is a mistranslation during the conversion process.
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
