dell xps problem with autocad 2018 lagging
Message 1 of 9
I have a dell xps 9570 (i9, 32gb ram, 1050ti ) and still autocad is laggy. I even tried a format to my laptop and still nothing. Also when starting the program it crashes and i have to do it 2-3 time to open it
Replies (8)
Message 2 of 9
jayhar
<<<<<I even tried a format to my laptop and still nothing>>>>
after format, Did not create new profile.
disabling your anti-virus program and then running AutoCAD
Is hardware acceleration enabled? TURN OFF
Have you installed the service pack? Click here
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 3 of 9
rkmcswain
Was it ever running okay on this PC? If so, what changed in between the time it was running okay, and now? If not, try logging into the PC as a different Windows user, and repeat your test. Any difference? Do you have a supported display adapter, with the recommended driver? Try running ACAD with no internet connection (disable WiFi, and unplug the ethernet cable). Any difference?
Message 4 of 9
How do i download the service pack?
Message 5 of 9
jayhar
https://www.autodesk.com/desktop-app
or Install desktop app, then you can see available updates
Jayhar
Message 6 of 9
I will adress my problem one more time to make myself clear, so when i
start my laptop and open the autocad it crashes and opens the send report
window. I have to do this 2-3 times to open the autocad and work.
Message 7 of 9
I had the lag problem from the beginning with the 2019 version of autocad
then i uninstalled it and installed the 2018 versio. It was running fine,
after 1 week it started crashing before i open it and the environment was
laggy
Message 8 of 9
jayhar
Fatal error when launching AutoCAD
Low disk drive space.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Obtainin...
Email the NFO file to technical support.
Message 9 of 9
rkmcswain
I offered three suggestions to try in post 3. Did you do any of them as a test?
