deleting arrows
deleting arrows
Message 1 of 14
deleting arrows
I am new to autocad but have been working with it for a few months. I am working with a drawing that has arrows that I can't delete. I don't know what else info to give to explain the arrows but would really like to get some help.
Replies (13)
Message 2 of 14
nestly2
Welcome to the Autodesk forums
Can you select them? If so what does the Properties Palette say they are?  Might they be on a locked layer?
A screenshot, or a sample drawing containing these objects would be helpful.
Message 3 of 14
nrz13
Without seeing your drawing, two things come to mind:
1) Turn off the UCS icon arrows:  enter UCSICON at the command line and then enter OFF.
2) If the arrows are in your drawing, verify that the layer the arrows are on is unlocked.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 4 of 14
I can select the lines and when I click properties, i get options:
general
- color
- layer
- linetype
- linetype scale
- plot style
- lineweight
- transparency
- hyperlink
3d Visualization
- material
I would send screen shot or the actual file itself but it's kind of sensative.
Message 5 of 14
ucsicon is set to off
Message 6 of 14
nestly2
What does it say just above "General"  that will tell us what type of object it is.  Also, we don't need a screencap of the whole drawing, just the "arrows" and maybe the properities Palestte while the arrow is selected.
Using Snipping tools to capture Screen shots.
Message 7 of 14
Kent1Cooper
@Anonymous wrote:
I can select the lines and when I click properties.....
Another way to find out:  LIST command, pick one of them, and press F2 to get the text screen.  It will tell you what kind of object it is, as well as various other information about it.
Kent Cooper, AIA
Message 8 of 14
When I click on the line, I then right click, go to properties, and the top box says, "ACAD_PROXY_ENTITY".
also, after clickingon the line, I type in LIST in the command line and then press f2 and it says
ACAD_PROXY_ENTITY Layer: "OBJECT 3"
                        SPACE: Model Space
Handle = 1a05e
dxf name:   AMDTNOTE
Class Name:    AMDTNOTE
Application Name:  acmsymBB
Product Description: Autocad Mechanical
company: Autodesk, Inc.
Message 9 of 14
Patchy
Very strange, usually deleting aec objects is not a problem, editing them is.
You probably need to install Mechanical Object Enabler for your autocad and see if it will let you delete that arrow.
Message 10 of 14
Do you have a link to the file?
Message 11 of 14
Patchy
Google search for mechanical object enabler, find the correct version of your autocad it will take you to autodesk web site.
Message 12 of 14
nestly2
Perhaps try copy/paste or WBLOCK everything except the "arrows" into a new drawing.
Message 13 of 14
I found the file and installed it. Restarted autocad and still not able to delete.
The only way I can work around it is to copy and paste the entire drawing into a new blank drawing and overwrite the existing file, but I have to do that so often it would just be easier to know how to delete the arrow in the first place.
here is a screen shot
Message 14 of 14
Have you ever tried a program called SuperPurge? I have it and it has purged and deleted objects that I could not figure out how to get rid of. If the drawings is not too sensitive and you would like me to try it, post a drawing and I'll give it a shot. I never tried it on a proxy entity, but it might work.
