Default programme choosing
Earlier I have used Autocad 2013 in Windows-7, 64bit O.S.
I have removed above programme and Installed Newer version of Autocad 2015,
Now when I am open any existing file to double click it's showing error (Picture attached for Reference).
I have tried some solution i.e.
On existing drawing file , Right click and choose Open with Option, then Click on browse & select Autodesk.exe file from the programming folder but it was not coming in the wizard.
help to resolve
Alfred.NESWADBA
Don't select here the exe-file, instead use the "AutoCAD DWG Launcher" as the default.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Mr. Alfred
Thanks for reply and I have followed the steps given by you but still the
same issue I have attached screen shot for your reference.
I didn't found AutoCAD DWG Launcher file in my system.
*Regards,*
*Pruthvirajsinh Chauhan*
*IT Assistant*
*Heurtey Petrochem India Pvt. Ltd.*
Por Workshop, Vadodara.
*CONFIDENTIALITY NOTICE*
*This email and the document(s) attached to it are exclusively intended for
the addressee(s). They may be confidential and also legally privileged.*
*Unless expressly authorized by the sender any storage, use, copying or
disclosure of any information contained in this email or the documents
attached thereto, either whole or partial, is prohibited and may be
unlawful. *
*If you have received this email and/or the document(s) attached in error,
please contact us immediately by email at **heurtey@heurtey.in*
* and delete such information from your system.*
*Since e-mail communications cannot guarantee the integrity of the
information shared, HEURTEY PETROCHEM S.A. and all their subsidiaries
disclaim all liability for any modification, distortion or falsification of
any email sent by them and/or document(s) attached thereto.*
Alfred.NESWADBA
Could be a defect installation then.
What was the exact order of your steps? Did you first uninstall 2013 and then install 2015 or did you first install 2015 and then uninstall 2013?
You might also try this exe (which is the DWG Launcher):
C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcLauncher.exe
Then start AutoCAD 2015 one time (using the icon on your desktop), close it and see if a double click on a DWG-file is working now.
If not, try to start AutoCAD with right-click onto the desktop icon and use option "start as administrator"
- alfred -
Alfred NESWADBA
First I have Uninstalled 2013 & then Installed 2015.1 Autocad.
I got that Launcher but still the same error.
If I first Open autocd 2015 and Click on Open then i can open any dwg file.
Photos attached.
Alfred.NESWADBA
Your first image is not an error messge, it's a question and so the dialog popup is ok, just click onto "Always reassociate DWG ...." ==> now all should work well
Your second image only shows the explorer with the acad.exe selected, but I don't know what you wanted to show with this screenshot.
- alfred -
Alfred NESWADBA
Thanks Now all DWG has open to double click on file. It's successfully done.
