Default Layer vs Properties Window
Does anyone happen to know why or how, when selecting an object the layer of that object would be different between what is shown in the ribbon layer and properties window layer?
It seems that when this user is using the top screen, ribbon layer selection with an object selected it only switches what the current default layer is, and not the layer property of the object. Otherwise when using the layer option in the properties window updates, but still remains the same in the top screen ribbon layer?
user181
Your PICKFIRST variable has to be set to 1 for the ribbon to change when you select something
