default icons not clear
dridaniel98
dridaniel98
I downloaded the version of autocad 2018.
Appnea I open the icons known for example command line, size and grainy polyline. I can fix this problem.
P.S. I have already tried to fix it as described on the autodesk website
Thank you have a nice day
dgladfelter
Sorry to hear you're having this issue.
At the risk of repeating the solution you've already tried, could you cite the troubleshooting steps you have already attempted?
Are you by chance using a 4K (high resolution) monitor?
Since around 2017, Autodesk has continued improving their support for 4K monitors (with 2019 being the best so far).
That said, additional 4K improvements were included in the latest AutoCAD 2018 update.
Have you installed the latest update; AutoCAD 2018.1.2 from the Autodesk Account website: https://manage.autodesk.com
Donnie Gladfelter
Virtual Design Manager, Dewberry
The CAD Geek Blog
Facebook |Twitter |YouTube |LinkedIn
dridaniel98
No, I don’t use 4k monitor, butti use fullhd monitor laptop. I install autocad 2018 version educational and i don’t know what is the version of this.
For information my laptop is Asus Zenbook pro 15 UX580 i7 and fullhd display
pendean
Community Legend
Community Legend
In AutocAD2018 start ABOUT command then post a screenshot of the pop-up that appears.
Also let everyone know what resolution and text scaling you are running Windows in on your laptop.
beyoungjr
I might also suggest that you consider using the newest AutoCAD version since you are a student.  You will not notice the differences from 2018 to 2019 as a beginner.  Your education community login will give you access to 2019 so if you elect to proceed with that be sure to uninstall 2018 completely and keep things fresh.
Cheers,
Blaine
Blaine Young
Senior Engineering Technician, US Army
Alfred.NESWADBA
Have you set the Windows text size (DPI-scaling) to a value other than 100%?
If so set that value back to 100%, reboot your laptop, start AutoCAD and verify the icons ... better?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
dridaniel98
Thank you
I fixed Autocad with the update
