Default distance for dynamic input
sgrya1
Message 1 of 8
sgrya1
A lot of the offset distances I use are the same number so I am CONSTANTLY typing in the number 125.
Is there a way I can have a keyboard shortcut which would enters "125" into the dynamic input box and hits enter for me?
Like I hit D" and it would do that for me?
Replies (7)
Message 2 of 8
ВeekeeCZ
- You can't hit just D. You can hit 'which would run a simple routine, but that loose the point, typing 125 would be faster.
- You can assign a function key to do that. One hit can fill 125 with or without <enter> at the end. Universal, you can use it in other commands, not just OFFSET.
- You can have a routine called D, which runs a regular OFFSET with 125 under last options <125>
(defun c:D nil
  (setvar 'OFFSETDIST 125)
  (command "_.OFFSET")
  (princ)
- You can pre-select 125 for OFFSET's "last" option just with a drawing launch.
(setvar 'OFFSETDIST 125) - This line has to be run on the start. You can use acaddoc.lsp, see HELP for more information.
Message 3 of 8
imadHabash
HI,
usually OFFSET command keep the last distance you enter.no need to always enter the number.
Command: OFFSET
Current settings: Erase source=No Layer=Source OFFSETGAPTYPE=0
Specify offset distance or [Through/Erase/Layer] <125.0000>:
Imad Habash
Message 4 of 8
SRSDS
Apologies. I didn't explain this correctly. Can you ignore the 'offset' term. It's often what I need to do but via dynamic input and _from command.
Basically, I want to be able to click on a line, for the dynamic input box to appear, and then hit a shortcut key that would enter '125' and then exit the command. This would make the line 125mm long, for example.
Message 5 of 8
dbroad
CTRL+V would save one keystroke, assuming you'd copied the value earlier.
Architect, Registered NC, VA, SC, & GA.
Message 6 of 8
SRSDS
Realized that I haven't explained it properly again...
One option is inputting '125' after the _from command.
Another would be entering '125' via the dynamic input.
I'm thinking the only way is using the 3rd party AutoHotKey programme and setting up a routine.
A lisp probably wouldn't work while a command is active nor any other method.
Message 7 of 8
ВeekeeCZ
As I proposed earlier...
Go to CUI, create new command, name it e.g. '125', add a macro 125, add this command between Keyboard shortcuts and assign some shortcut you don't use. You can even assign some F-key, if there is a one which you don't use.
See the SCREENCAST
Message 8 of 8
john.vellek
Hi @sgrya1,
Did @ВeekeeCZ's suggestion help you to create your button?  Once you have it created you could even set it to read a variable. Then when you start a drawing you can set the proper value for the variable when you start.
For instance, if you set the variable name to "My_Num" in your button, at the command line you would just have to SetQ My_Num "125"
John Vellek
