Dealing with Nodes, Join command and tolerance
If you draw two lines (not a P Line), and you want to join them later, why does the join command fail?
If anyone can, I would love for the most in depth complicated answer possible.
Like how is it possible to draw two lines that are on the same plane, with overlapping endpoints.....
close the file...
re-open the file the next day and the lines wont join.
What is going on here?
How does autocad read the inputs and interpret the locations in model space?
If you draw three lines with overlapping end points, how does autocad determine which lines to join?
What is the order in which autocad reads through a command process and where might it be confused given the order in which I run the command?
What is the correct order of operations to ensure that when you draw two lines with overlapping endpoints autocad will understand that these two endpoints occupy the exact same point in space?
Is there a file tolerance setting? Does autocad have multiple c-planes?
Why is autocad seem so inaccurate?
