Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I ve been trying to extract the data from points on the line (I used the MEASURE command to create points).
In the data extraction set up page, I chose the object as a point and properties as Position X and Y.
I selected 5 points on the line which the result should give me 5 coordinates but it suddenly gave me thousands of row.
If someone knows how to fix this, please notice me which part i ve done wrong.
Solved by Alfred.NESWADBA. Go to Solution.
Hi and Welcome to AutoDesk Forum,
I suggest to install the latest updates and Service pack.after that if NO success please attache your drawing here as CAD file for testing.
Note: would you please finish all the procedure (page 8/8) and see if you got the same result.
Imad Habash
Look to page 2 of the wizard, which option do you have selected (second/lower one would be the correct one, otherwise all objects are used for extraction).
- alfred -
I have 269149 data coordinates should be get data coordinates, but when I do using lower one, I get 65536 Data Only.
Please give me idea.
general rule of forums: Another issue, another thread!
65536 is the limit for microsofts .xls file format.
Workaround/solution:
Split your job to 5 tasks
Or use another tool to extract your information,
is can be a faster and smarter way
and by using .xlsx.
Or use another fileformat which allows more rows.
Have you tested .csv?
Sebastian
