Anuncios
DATA EXTRACTION
DATA EXTRACTION
No aplicable
Hey there,
I need some help with Data Extraction of a Lots Map.
Each Lot (Polyline) has a text as LOT Number.
Area in the Database are showing for the Polyline but without the LOT Number(Text).
ANY SOLUTION PLEASE ?
N.B: More than 5000 Polyline and Text.
Please Refer to the Photo for the Situation.
Warm Regards,
0 Me gusta
Responder
496 Vistas
3 Respuestas
Respuestas (3)
Alfred.NESWADBA
Hi.
welcome @Anonymous.autodesk.com!
As long as you don't have Map 3D or Civil 3D or any application there does no exist any function to determine which text belongs to which polygon, so DATAEXTRACTION can't output them together/combined.
If you have any vertical product or application on top of AutoCAD let us know which one.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
TheCADnoob
The data is there, its just a little messy and a long walk around to get there. Each text has an x, y and the polylines will have relatively close x , y. Dataextraction does not pull the polyline x , y so you would need somehting to pull this info for you. Something like ( http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/data-extraction-from-polylines-and-ar... ) I would pull the verticies and lengths. You can match the lengths to the information in the data from dataextraction and you can get a fairly good approximation by matching the x , y of the Text and the Poly line verticies. You will have to do a lot of excel work to get this to work and you will undoubtably have to deal with problems with proximity of the text coordinates and the poly line coordinates so a QC would have to be run, but i think it might be doable. Given the scope of the task i would give it some thought.
CADnoob
0 Me gusta
owen66
is your source dwg available?
"Aah, there's nothing more exciting than science. You get all the fun of sitting still, being quiet, writing down numbers, paying attention...science has it all."
0 Me gusta
