Hello everyone,
I just learned how to extract data from blocks and have it generate a table. Let me first explain what I am trying to accomplish:
I need the table to look a certain way for Fire Alarm programming purposes. Each device or module has an address which is listed in alphanumerical order. We are currently showing a table with each address associated to each device. We intentionally leave spaces between devices in case we forget a device and need a place to put it.
So far, everything is working great, but we are use to showing the spaces between addresses. So far it does not let me do this. Attached is a pdf showing more clarity.
Obviously we can still come back and place devices later because to table will auto populate these values. However, it is easier to persuade management if the aesthetics are the same or similar (its all about how it looks once printed).
Does anyone know if this is possible? Maybe there is some one to simply place the exacted data into an existing table that I already have?
