Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Data Extraction - Sorting Numbers in the Table
Jaiyakumar
Jaiyakumar
I have used the Data extraction to do some setting out coordinates in Auto CAD 2016.
After, Added all the information the numbers seems to be not sorted as Ascending.
Can any one tel what is the problem or Should I do add more process to it which I missed?
Please any one help me!!
Screen Shot attached
Sorting Number in Data linkSorting Number in Data link
Replies (8)
imadHabash
is it applicable to share your CAD .dwg file with us here for testing please ?
Imad Habash
john.vellek
Hi @Jaiyakumar,
If you have three digits then you need to use 001, 002, 003...format for everything to sort properly.
John Vellek
Jaiyakumar
Hi John,
Thanks for your reply.
I gave shot of your solution but by changing the every time the decimal value - it is definitely tired job.
As, In most of our project the number keep on exceeding from three decimal to four decimal in every revision based on the construction process.
Can you suggest me any other solution - any other option to try in Auto Cad, please?
Thanks & Best Regards
imadHabash
>> Can you suggest me any other solution <<
i suggest to read and follow this link that may help . >> Click <<
Imad Habash
Jaiyakumar
Hi Imad,
I appreciate your effort to reply to the issue.
I have attached the .dwg, Data EXtraction file (.dxe) and .xl file (I have tried the solution from the link which you have sent me previously- which seems also to be not working).
I am not sure - if there is any problem with the attribute whic make this extraction in a wrong sorting order.
Please have check and let me know your comment on this.
I am eagerly waiting to crack a solution for this issue.
john.vellek
Hi @Jaiyakumar,
I do not know of other ways to get this to sort any differently.  You can try using Find/Replace to add the leading 0 to existing attributes to make this easier.
John Vellek
cadffm
You only need to set the column to Integer(whole number), because  integer attribute values
(and your "01" what is only a valid string, no number) does not automatically recognize  as numbers.
For real numbers this would be the case.
DataExtract, Right Click to the Column-Header, set Column data format...
Or did I not understand the problem?
Sebastian
Jaiyakumar
Hi @cadffm,
Thank you for your reply in this issue.
I will have quick try and check on this and come back to you.
