Data Extraction - Select Objects
sam_wegener
sam_wegener
Good day
I am needing to extract several hundred points from AutoCAD to Excel. The AutoCAD file is attached for reference.
When using the DATAEXTRACTION command, I am able to complete pages 1 and 2 of the data extraction process ("Begin" and "Define Data Source"). However, after selecting the points in model space using the "Select objects in the current drawing" option, there are no object shown in page 3 ("Select Objects"). Screenshot attached for reference.
Please urgently advise. How may I complete the extraction of the points to Excel?
Many thanks
Sam
imadHabash
I succeed to reach to page 3/8 when i explode those blocks .. you just have a blocks in your drawing .
Imad Habash
pendean
Community Legend
Community Legend
Are you looking to extract the x,y,z locations of each of your blocks to Excel?
ChicagoLooper
Hello @sam_wegener
What is it, bathymetry? Coastline?
Is this a survey and was it originally drawn using Civil3D?
If you are trying to create a surface, then you'll need to disclose the location so an appropriate coordinate system can be assigned.
Chicagolooper
Pointdump
Hi Sam,
Thanks for posting your drawing.
Those are all "Anonymous" Blocks. Use Command UNANONALL in this LISP to convert them to regular blocks named TEMPXXX. Then you'll be able to use Data Extraction.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Pointdump
Hi Imad,
I learned something new on this thread. EXPLODE Command didn't work before with Anonymous Blocks. It sure does now. But there's a problem. Most of the Blocks in Sam's drawing explode into AutoCAD points. But 1835 of the Blocks explode into 2 lines. (+) So on those 1835 blocks you'll want to use UNANONALL Lisp to convert to regular blocks. Then Data Extraction will quickly pull all XYZ's from the drawing. XLS file attached.
Dave
Dave Stoll
Las Vegas, Nevada
