Hi Guys,
I've successfully set up a data extraction table to list active blocks in a drawing. However, several of the blocks have dynamic visibility. When the table was first set up, everything worked fine ('Template 1' attached) and listed/counted the different visibility states for a specific block. But when I change the visibility of a block in the DWG and refresh, the table rows fail to update properly ('Template 2' attached). Essentially, the table 'area' seems fixed and wants to 'wrap' rather than add a row to the bottom. How can I make the the table add the extra rows in a vertical fashion?
Thanks guys!
Link copied
