AutoCAD Forum
Data Extraction combine row not working with dynamic block - BUG
1 REPLY 1
lthiffeault
241 Views, 1 Reply
Data extraction "Combine identical values" won't combine rows when extracting values from dynamic block. I'm extracting a linear parameter labeled "Spacing", turned on as "Show properties" in block editor and shown in "Custom" category in block properties.
Also, ".dxe" file upload is not supported in the forums... seems counter-productive. See zip file for DXE.
1 REPLY 1
cadffm
in reply to: lthiffeault
the problem is: They are NOT equal,  decimal place 12, what is outside of displaying AutoCAD number accurancy.
(there are just some rare exceptions where AutoCAD shows more than 8 decimal digitals, but the program alway working with more - if possible)
And in dataextraction or also tables, AutoCAD will ever working with the real data, not with the displaying roundet /modified values.
You can see the problem if you change the data format to Text!
I tried a fix, but it can not fix the float problem.
(I set Bridging left/right to incremental 0.5 steps and visible inproperties palette,
this way can set both so I could set both values accurately.
As a result, the spacing should also be accurate, but it could not solve the float problem satisfactorily.
(nevertheless, I would not only set these parameters freely with the handle, but incrementally and maybe also visible in the properties)
Sorry
Sebastian
Forma Design Contest
