Dashed lines
Dashed lines
ema.drnda02
Dashed lines
ema.drnda02
Hi everyone, hope to find some help here.
I have set up couple of different dashed lines in my drawing with different density. When  se up my line type do 500 in the layouting window, all my lines print in the scale I want, except one. How do I change this effectivly?
Thanks in advance.
john.vellek
Hi @ema.drnda02,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
If all the lines are working correctly except one, please use the Properties palette when selecting the one line to see if there is a scale override applied to the line.
John Vellek
@ema.drnda02 for your problem you have to check in the layouts and what you want from drawing in different lines.??
john.vellek
HI @ema.drnda02,
I am checking back to see if my post helped you with your problem or question. You are welcome to attach the file to a post if the problem continues. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
ema.drnda02
Hi John,
Sorry for replying so late. I am new to this forum and needed some ajustment and to understand how t works. The E-Mail landed in my spam but now I arranged it. It helped me!
Now I have a completely different problem.Can I ask here or create a new question?
It is about X-Refs i 2019 Version of autocad. The wont close and safe.
Kind regards!
cadffm
@ema.drnda02
You should open a new topic for a new question if you have not found a suitable solution via the search function,
so the question would be placed incorrectly here.
You did it right and started a new thread here:
The new question about XREF 2019 is discussed here: https://forums.autodesk.com/t5/autocad-produktfamilie-deutsch/xrefs/m-p/8074397
(However, it is not welcome when you re-created several threads on the same topic "Crossposts", like here: Click! )
By the time you find yourself in the forum and how you should work with it, no problem ..you're welcome.
Sebastian
