Dashed lines issues
Dashed lines issues
milianjr
Message 1 of 14
Dashed lines issues
milianjr
Dashed lines in Model space are shown as continuous when I zoom out of the drawings and zoom back in. After that I have to reset the scale with LTSCALE from 1 to 1.1 and do this back and forth every time it changes. Any help is very appreciated.
Replies (13)
Message 2 of 14
TomBeauford
Just enter RE at the command line to REGEN the drawing to reset the display.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 3 of 14
milianjr
That saves me changing the scale, thank you! but on the main issue, how can the it be prevented from happening at all?
Message 4 of 14
Kent1Cooper
@TomBeauford wrote:
... RE at the command line to REGEN ....
If that fixes the display of noncontinuous linetypes for you, you will need to do that far less often if you use the VIEWRES command [answer "Yes" to the question] to set the circle zoom percentage value to a higher number -- may as well go all the way to the maximum 20000.
Kent Cooper, AIA
Message 5 of 14
vinodkl
Hello @milianjr
Seems to be like a graphic issue. In the command line type in the command "3DCONFIG" and try turning it "on" if its turned off and see if that resolves the issue 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 6 of 14
milianjr
Hello @vinodkl,
The Hardware Acceleration was already turned on. I don't know if this helps, the Video Card is NVIDIA GeForce RTX 2070 Super with Max-Q Design, and the 2D Display Settings is in "Advanced Mode". This is information shown on the same window from  "3DCONFIG". Thank you for the help.
Message 7 of 14
vinodkl
Hello @milianjr
Hmm. Do you have the same issue in other drawings as well?
Also I don't see the graphic card which you are using in the list of certified graphic to be used with AutoCAD 2023.
Message 8 of 14
milianjr
Yes, it happens on all drawings.
Message 9 of 14
vinodkl
Hello @milianjr
If possible can you share us your drawing so that we can test it from our end? Also it would be helpful if you could share the screen recording of what you are seeing to know more about that situation 🙂
Message 10 of 14
milianjr
Thank you for the help @vinodkl . Here's the link to the file: https://www.dropbox.com/t/2XO8ZO9HKqg2xzyH
And here are some screenshots of the issue. Before zooming out:
After zooming out:
Message 11 of 14
Valentin_CAD
@milianjr ,
MSLTSCALE and PSLTSCALE should be set to 1 - try this link:
or these other suggestions:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 12 of 14
milianjr
Thank you @Valentin_CAD. I tried switching "MSLTCALE "from "1" to "0" and vice versa but it did not solve the issue.
Message 13 of 14
vinodkl
Hello @milianjr
Try the attached drawing. I have set the layers of the dashed lines inside of the block to layer "0" and then set the layer of the dashed line block in workspace to "GT ROOF". See if this drawings works as you expected.
Also just wanted to know on which version of AutoCAD are you working and is it updated with the latest release. Check the graphic driver also if its updated to latest release.
Message 14 of 14
milianjr
Hello, It seems like it's a problem on my end, maybe something with the video card. I should be replacing the laptop soon, I will come back if changing it does not fix the issue. I'm greatly thankful for the help.
