Anuncios
Dashed Lines Appear Solid When I Try To Save or Print the File
No aplicable
I am using AutoCAD 2020 and I am trying to use ACAD_ISO02W100 (Dashed Line) in parts of my drawing but whenever I got to print or save, the lines appear as solid. I have no idea why this is happening considering the lines look dashed in my model space. Please help.
0 Me gusta
Responder
Soluciones aceptadas (1)
3.357 Vistas
6 Respuestas
Respuestas (6)
Patchy
 PSLTSCALE  use 1
Does it change?
0 Me gusta
Michiel.Valcke
Could you share some examples?
I would definitely check the zoom scale you're using when printing your drawing. Also check the linetype scale variables LTSCALE and PSLTSCALE
0 Me gusta
vinodkl
Solución aceptada
Hi @Anonymous
Type in the command "PSLTSCALE" and set it to "0" and see if that's what you are looking for :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
Setting the PSLTSCALE system variable = 1  allows to maintain the same linetype scaling for objects displayed at different zoom factors in a layout and in a layout viewport.
Imad Habash
0 Me gusta
s.borello
What is your LTS in model space?  Try setting it to 1.
0 Me gusta
No aplicable
Setting it to "0" worked, thank you
0 Me gusta
