dashed line that follows a cursor
Message 1 of 19
I was wondering how to shut off the dashed ref line that shows up when you do an edit such as (for ex.'s) copy or move or rotate  an object from one point to other places, it is the line that connects from the grip of the copied entity back to the original point of copy. I don't know what it is called, and it only shows as a ref dashed line that moves with the cursor until the command is finished. It isn't an actual line. I am also what purpose it is there for. Thanks tony
Replies (18)
Message 2 of 19
RobDraw
That cannot be turned off or adjusted in any way. Please see:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Rob
Message 3 of 19
leeminardi
Do you mean the "rubber band" that  goes from the initial cursor click location to the current cursor location in a move command?  If so, may I ask why?  The rubberband is an option in VLSIP when specifying a point location
lee.minardi
Message 4 of 19
imadHabash
if you're talking about the cursorbadge, you can turn it off by CURSORBADGE system variable. if you set it to (1) it will Turns off cursor badges used in the following commands: AREA, COPY, DIST, ERASE, ID, LIST, MASSPROP, MEASUREGEOM, MOVE, ROTATE, SCALE, TRIM, and ZOOM.
Imad Habash
Message 5 of 19
john.vellek
Hi Tony,
Did any of the posts help or is this something else still? Can you take a screen capture or make a Screencast to show what you are having appear on your screen?
John Vellek
Message 6 of 19
looks like its something that cannot be changed in this version per Robdraw so it's okayt get used to it:
Re: dashed line that follows a cursor
02-10-2017 08:57 AM in reply to: ahartofelis
Message 7 of 19
Hi
I had the same problem whilst using Autoplant 2017.
I hit the F10 button on my keyboard and it cleared it.
Message 8 of 19
imadHabash
in AutoCAD .... F10 ( Polar tracking ) used for Guides cursor movement to specified angles >> Click << . the OP was asking for the rubber band .
Imad Habash
Message 9 of 19
jearleywineZWKKW
I don't know if this is what was annoying Tony. But, this is the line that's annoying me.
Message 10 of 19
jearleywineZWKKW
Here's another example.
I'm trying to snap to the cyan diamond, but because of the green dashed line the crosshairs are not locating the white line with x's (the cyan diamond).
Message 11 of 19
ВeekeeCZ
F10 ?
Message 12 of 19
jearleywineZWKKW
It does act like the ORTHO feature but it was off when in this instance.
Message 13 of 19
Kent1Cooper
@jearleywineZWKKW wrote:
.... the green dashed line ....
Polar tracking is on.  Turn it off with the F10 key.
Kent Cooper, AIA
Message 14 of 19
jearleywineZWKKW
My Polar is set to 45° and it was not tracking the 45° direction only the 90° direction.
Message 15 of 19
jearleywineZWKKW
Also, it was like it was extending in the 90° direction especially if I moved the crosshairs in a 90° direction
Message 16 of 19
pendean
Community Legend
Community Legend
@jearleywineZWKKW Tip is above your post
Message 17 of 19
jearleywineZWKKW
I know what the polar feature does... I'm not a noob.
Message 18 of 19
ВeekeeCZ
Or F11.
Message 19 of 19
jearleywineZWKKW
Thanks to those who tried to help. But I figured it out on my own.
It's called Object Snap Tracking. It tracks the cursor along vertical and horizontal alignment paths from object snap points.
