cycle through layers does not work anymore
ernstQ9LLC
ernstQ9LLC
the following error occurs: Normally i can select some lines and objects and then i select another layer in the drop down menu of layers. (it then changes the layer of my selected objects in real time + color changes + layer type etc.) but on this machine the layer drop down window just closes and the selected objects stay on the same layer like before  as soon as i hover over another layer. Same thing happens if i try that with hatches. So i have to change them via the properties window. Does anyone have a clue what could cause this Situation?
im using Auto cad 2020 64bit with Athena 2019 on Windows 10.
0 Me gusta
Responder
1.143 Vistas
12 Respuestas
Respuestas (12)
vinodkl
Usually this happen when the PICKFIRST variable is set to 0. Type in the command "PICKFIRST" and set it to "1". Now try changing the layer from the layer dropdown:cara_con_una_leve_sonrisa: Hope it solves your problem.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
ernstQ9LLC
thank you for your fast reply.
Sadly that only changed the situation that after i try to change the layer, the objects look like they are deselected. (because pickfist "1" was set i tried to see the difference to "0") but as soon as i click the object again it shows the previously selection.
pickfirst variable was already set to 1
0 Me gusta
vinodkl
Could be a temporal issue. Can you try restarting your system and see it goes away. If it doesn't help can you download  the free tool Screencast from Autodesk from here to record your screen and share it so that we see what's going on your end?
0 Me gusta
ernstQ9LLC
HI,
here i tried to create that screencast thing when trying to select another layer, i hope it helps to analyse the problem.
0 Me gusta
ernstQ9LLC
Here is the screencast.
0 Me gusta
imadHabash
if you turn OFF hardware acceleration from GRAPHICSCONFIG command , any changes ?
Imad Habash
0 Me gusta
ernstQ9LLC
Hi imadHabash,
i turned off the hardware acceleration after using graphicsconfig command
but i didn't notice any difference except the arrows and measurement lines
looked like hatches now. But the window closing still happens unfortunately.
I tried to post a screencast but i think the embedd link didnt work so maybe
this link helps somehow:
https://knowledge.autodesk.com/de/community/screencast/a9986c05-294a-475d-b9
bc-2db30bdc3a0a
0 Me gusta
vinodkl
Have you tried restarting your system and see if the problem goes away?
Also, check if your AutoCAD 2020 is updated to the latest version. If not update it. Still, if it doesn't solve your problem then reset AutoCAD to defaults. Here is how you can do that "click here"
0 Me gusta
pendean
Community Legend
Community Legend
What is "with Athena 2019" mean to the rest of us?
Can you unload it to test AutoCAD 2020 without it?
Do you have the 2020.1.3 update installed? ABOUT command will confirm if you do or not, it is required.
0 Me gusta
ernstQ9LLC
Hi, restarting the Computer didn't help.
I acutally cannot unload Athena. It's an addon to place metal objects as blocks.
But even before i had to install that Extension the AutoCAD behavior was like listed above.
I know that this Scrolling through layers and hatches should work, because everywhere else (Computer of working colleagues ) it's working.
0 Me gusta
timothy_crouse
So here is a hail mary
I have had to tweak the aperture system var to get better selection performance in 2020.
I doubt it relates to the UI but its worth a shot.
Try setting it to 10.
The problem could be related to the GUI only (UI interface behavior)
Try changing the resolution of your screen (for the test)  Make the resolution a bit larger to give the mouse icon more area to work when you are selecting items off a menu.
-Tim C.
ernstQ9LLC
aperture variable changed from 3 to 10 to 20 to 50 neither of that worked.
i also think it is a mix between hardware or gpu problem with this video card and maybe this athena program configuration.
so i think i will have to live with the current way to change it via properties window instead of the common way :cara_de_decepción:
thank you anyways for you help :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
0 Me gusta
