Customize ribbon / tabs & palettes
No aplicable
In a previous office (running ACAD 2000), running a custimised ACAD.MNC file, we were able to create a custom drop down menu for standardised layers. This drop down menu was a "list" of all layers for the office and when a particular layer was selected, the a script would execute to create the desired layer with all the standard properties (if it was not already created that way).
My question...how can I "translate" this to work with ACAD 2016's Ribbon / tabs & Pallets?
Many thanks, S
0 Me gusta
Responder
375 Vistas
2 Respuestas
Respuestas (2)
pendean
Community Legend
Community Legend
Do you really want to conver it to a panel? Or just bring it in? Pulldown menus can be turned on in R2016 too.
Quick fix: CUI command has a TRANSFER tab you can use to open your old MNU/MNS/MNC file, then drag and drop into 2016's "pull-down" menus section. Save and close CUI, then turn on pulldown menus in your workspace (and remember to save your workspace after all of this with WSSAVE command).
0 Me gusta
dgorsman
In the CUIx system you create command definitions (different than command-line entries).  These are much the same as how XREFs are used - one definition, used in multiple places (Ribbon panel, menu drop-down, toolbar, and so on).  In the Ribbon you may have a small number of buttons for common layers and a drop-down for less common layers; each individual button calls one function, and each entry in the drop-down also calls one function.
0 Me gusta
