Custom LISP file add multiples
bemmer7MZ3G
bemmer7MZ3G
I have a custom LISP program that works great, however it only selects one at a time. Is it possible to add a multiple selection option?
0 Me gusta
Responder
Soluciones aceptadas (1)
887 Vistas
8 Respuestas
Respuestas (8)
vinodkl
Hello @bemmer7MZ3G
Does this work? See attached :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
bemmer7MZ3G
It says:
"Select objects: 1 found, 3 total
Select objects:  ; error: bad argument type: consp <Selection set: 1fc7>"
0 Me gusta
vinodkl
Hello @bemmer7MZ3G
Try this lisp from @Kent1Cooper :cara_con_una_leve_sonrisa:
bemmer7MZ3G
I am not sure what is wrong, but that lisp does not work for me at all. Here is part of the file I am working on. I am attempting to convert these polyline circle-like shapes into circles.
0 Me gusta
vinodkl
Hello @bemmer7MZ3G
From the drawing, I could notice that the closed polyline are not equidistant so they won't be called polygons. You would need a different lisp to work on your requirement.
Apologies, my knowledge of lisp is not very much:cara_sonriente_con_la_boca_abierta_y_sudor_frío: so here is what I found on the forum(See attached) which would work on your requirement. Credits to @Kent1Cooper :cara_con_una_leve_sonrisa:
Type in the command PLS2C to execute the lisp.
Kent1Cooper
Mine called PolygonToCircle.lsp doesn't work in your sample drawing because it requires regular polygons such as the POLYGON command makes [all edges the same length, all vertices the same distance from the center], but:
The one called PLS2C.lsp does it by drawing a 3-point Circle through the starting vertex and two others approximately 1/3 and 2/3 of the way around, so how the resulting Circle relates to the original Polyline can very a lot depending on how close to circular the original is.
Kent Cooper, AIA
bemmer7MZ3G
I have attached the original file I made which does work on these. I just need to select multiple. I think swapping in SSGET does not work because then it tries to run on the entire selection set instead of each entry. I do not know how to get it to reference each entry as it passes through but I believe I have the loop part correct. The one labeled "Modified" is not currently working and has the loop, the other one works but only on one selection at a time.
0 Me gusta
Kent1Cooper
Solución aceptada
Here's my approach to [only] adding multiple selection.  I haven't analyzed their method of determining the diameter, but that may be applicable only in some situations, because the command works if I select only the sort-of-circular Polylines, but it hangs up if I include more in the selection, i.e. parts of the Big M.  I would have expected it to make a Circle of some kind and remove the M part, but it stalls instead, and I haven't studied it enough to understand why.  I could try a different diameter determination if this one's problem is a problem for you.
Kent Cooper, AIA
