Custom linetype
Custom linetype
dieter.desmetUGQY9
Observer Observer
Custom linetype
dieter.desmetUGQY9
Observer
Observer
Is it possible to create a linetype that looks like this?
Its basically a dashed line where the gaps are closed by a line at the top and at the bottom.
I've tried to create this as a linetype, but I can't get it to work as most of the time I get: *Invalid* That's the continuous linetype!
Using MLINE also doesn't work.
Alfred.NESWADBA
if you need this linetype for none straight objects I would say, no, at least not clean as the outlines look then like segments. If you only need straight segments then it could be possible.
If you have Map3D or Civil3D then this video might help:
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Kent1Cooper
I'm pretty sure something just like this has been requested before.  I tried Searching a little, but didn't find the right terms to put in the Search window, but you can try.  And it could have been either here or [maybe more likely] in the Customization Forum.
Kent Cooper, AIA
dieter.desmetUGQY9
Observer
Observer
Thanks for the reply.
I do not have Map3D or Civil3D, but I will look in to it if I don't find any other solution.
dieter.desmetUGQY9
Observer
Observer
Thanks, I already searched for it but couldn't find anything.
I now searched again and the only thing I could find was this: https://forums.autodesk.com/t5/autocad-forum/create-linetype-with-multiple-lines/m-p/7722924
This one uses multilines, but its not giving me the result I'm looking for.
pendean
Community Legend
Community Legend
FYI Map3D is free to use for each and every AutoCAD user with a current active subscription: just download and install from your Autodesk Account Page.
