Anuncios
custom hatch pattern
thomas.middendorp
thomas.middendorp
I am trying to make a custom hatch pattern voor a brick wall.
The horizontal lines are no problem, the work great, but the vertical ones do'nt add up.
They are nog positioned the way I though I typed them in to the *.pat file.
For some reason they shift in the vertical direction, but not in a disctance that I set it up.
Can someone please give me some advise
thans a lot
forgot the *.pat file
*BLOK, blokpatroon fbc
0, 0,0, 108.5,106, 207,-10
0, 0,43, 108.5,106, 207,-10
0, 0,53, 108.5,106, 207,-10
0, 0,96, 108.5,106, 207,-10
90, 0,0, 217,0, 43,-10,43,-116
0 Me gusta
Responder
484 Vistas
4 Respuestas
Respuestas (4)
thomas.middendorp
I forgot the *.pat file:
I know there need to be more vertical lines written, but the first is already wrong so I need advice first
0 Me gusta
hugha
try this:
; Written by HatchKit Professional
; HatchKit Professional (c)1990-2019 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2020-03-07
;-Time : 12:13:02
;-HatchKit Version : 3.1.11.2740
;-HatchKit Output Filetype : AutoCAD format
*metselwerverband,DXF Entity Section
0,0,0,-108.5,-106,207,-10
0,0,53,-108.5,-106,207,-10
0,0,96,-108.5,-106,207,-10
0,0,43,-108.5,-106,207,-10
-90,0,43,106,108.5,43,-169
-90,0,96,106,108.5,43,-169
-90,207,43,106,108.5,43,-169
-90,207,96,106,108.5,43,-169
hope this helps,
Hugh Adamson.
0 Me gusta
Kent1Cooper
A confusing thing about Hatch pattern definitions is that for linesets at other than 0 degree angles, the origin point is still defined in relation to the 0-degree direction, but the X & Y offsets are defined in terms of the rotated  direction.  I think [without trying it] that your 90-degree line:
should have its offsets done differently, something like:
90, 0,0, 106,108.5, 43,-10,43,-116
[reversing the X & Y offset numbers from the horizontal lineset definitions, because of the 90-degree rotation], and then another for the other sides of the vertical joints:
90, -10,0, 106,108.5, 43,-10,43,-116
But I think the verticals can all be covered in just the two  lineset-definition lines.
Kent Cooper, AIA
0 Me gusta
Kent1Cooper
... and having tested it now, I find those lines do work:
Kent Cooper, AIA
0 Me gusta
