Custom Hatch Pattern - LVT
trEQ4GG
Message 1 of 22
trEQ4GG
Hello!
I am trying to create a custom hatch pattern for a 6.25" x 42" LVT plank with a 33% offset. For whatever reason, I have had extreme difficulty creating custom hatches and getting ahold of autodesk to trouble shoot over the phone has been difficult. I am not sure why it doesn't work out for me. I have attached a screen shot of the protocols we follow at work that USED to work for me. Below is what I have put into the .pat file, yet its not there when I open cad up again...
*LVT 6.25x42 33% Offset, LVT Pattern
0, 0,0, 14,6.25, 42,0
90, 0,0, 6.25,14, 6.25,-12.5
it was saved as "LVT 6.25x42 33% Offset"
Thanks for the assistance!
Replies (21)
Message 2 of 22
Kent1Cooper
Try it without the pen-down/pen-up numbers at the end of the first line.  I think I've seen the same problem before -- that it doesn't like a zero-length pen-up, which in any case should be negative.  Those lines are continuous anyway -- no need for pen-down/pen-up.
0, 0,0, 14,6.25
You might be interested in RunningBondHPG.lsp, >here<, which can construct the pattern definition of something like that for you.  You just give it the element size and the amount of stagger you want.
Kent Cooper, AIA
Message 3 of 22
pendean
Community Legend
Community Legend
Is this the error you get, or is it something else? You never quite show it
Just change the name of the pattern and file, see attached inside the ZIP file, it works great
Message 4 of 22
trEQ4GG
I don't get any errors, the hatch pattern simply won't appear in my custom hatches via the folder path I put it in. Once I put the custom hatch in the folder, it will be available upon opening autocad next. This custom hatch file won't even show up in autocad as an option to use.
Message 5 of 22
pendean
Community Legend
Community Legend
See the other half of my earlier reply: works great after the change
Message 6 of 22
pendean
Community Legend
Community Legend
@Kent1Cooper wrote:
...I think I've seen the same problem before...
A week or so ago, turns out it was a file naming convention only TILE_3x12_33Offset.pat
Message 7 of 22
Kent1Cooper
@pendean wrote:
..... turns out it was a file naming convention only....
Ah, yes.  In a pattern defined in its own file, the file name and the pattern name must be the same, so if something like their % sign is not allowed in both AutoCAD Hatch pattern names and computer File names, it won't fly.
Kent Cooper, AIA
Message 8 of 22
trEQ4GG
The file you gave, I put into my custom hatch folder, and it doesn't appear in autocad still. I wish I could screenshot the menu to show that it is not there, but the menu is dependent on you staying in the hatch command.
Message 9 of 22
trEQ4GG
This solution did not work, as for the running bond file, that is extremely in depth and a little confusing to follow, I don't know where to start to edit it...
Message 10 of 22
trEQ4GG
Okay, here is a file of a custom hatch pattern created that WORKS...I'm literally doing the same thing as this file yet I am met with consistent issues.
Message 11 of 22
pendean
Community Legend
Community Legend
You have to choose CUSTOM
@trEQ4GG wrote:
...I wish I could screenshot the menu to show that it is not there, but the menu is dependent on you staying in the hatch command.
Your keyboard has a PRINTSCR or PRINTSCREEN or PRT SC button, use that then paste into AutoCAD or MSWord or Windows Paint.... .
Message 12 of 22
TheCADnoob
When i changed the Hatch and file name to LVT, it worked with no issues.
CADnoob
Message 13 of 22
pendean
Community Legend
Community Legend
There is no
.25
 in the name
Message 14 of 22
trEQ4GG
That is because the size is 6"x36" not 6.25"x36". I am trying to create a 6.25"x42" LVT pattern. I should be able to follow the custom hatch instructions I have been using with no issues. I gave that file as an example to show that I name things with a % and save them with a % and it works.
Message 15 of 22
trEQ4GG
LVT is in the name and the file name for the original hatch I created. here is what I am trying to create and its not working.
Message 16 of 22
Kent1Cooper
It may have not worked because of invalid characters in the pattern / file name.
The running-bond file is not for you to edit [except for the file path] -- it's not a pattern, but a pattern generator.  Load it, enter the RBHPG command name, and answer a few questions, and it will build the pattern definition and the file for it.  [But do the editing needed for the filepath you want it to use.]  It made the attached in seconds.  You have your choice of whether the 1/3 stagger goes left or right.
It comments that [the reason for @pendean's post about this] a period is not accepted as part of a pattern name, and / is not in a file name, which is why it substitutes other characters, so that the same name can serve for both [they must match].
Kent Cooper, AIA
Message 17 of 22
TheCADnoob
When i change the name to just "LVT" the hatch works (both of them). There is something with the name that its not happy with.
CADnoob
Message 18 of 22
Kent1Cooper
@TheCADnoob wrote:
..... There is something with the name that its not happy with.
Again, it's the period/decimal-point in it.
Kent Cooper, AIA
Message 19 of 22
TheCADnoob
agreed. Just trying to illustrate that changing the name is a simple way to nail down the cause.
CADnoob
Message 20 of 22
TheCADnoob
something else that may be causing you issues is adding the last line break. Make sure that you have a carriage return to the last line in your file. You cursor should be on the next line with no chars in it.
CADnoob
