Hi everyone,
I'm relativity new to creating custom hatch patterns. What I'm trying to do is create a pattern that is a composite of ANSI32 (steel) and horizontal lines that are spaced 1/8" between (The goal being that that for a 3/4" thick rectangle, there would be 5 visble line between the edges).
The code I'm using
*Plywood,Plywood 0,0.125,0,0,0.125 45, 0, 0, 0, 9.525 45, 4.49013, 0, 0, 9.525
the goal is to have something that looks like this;
What keeps on happening is this:
I'm confused. What I conceptully understand is the syntax being (angle of line), (X orgin), (Y orgin), (delta X), (delta Y) and parameter's for line attributes. What I don't understand is; if I set the delta Y for .125 (1/8"), scale factor 1, why am I not seeing horiznational lines at X=n*0.125 increments?
Joe
