Anuncios
Custom Dimension Style w/o dimension line
No aplicable
I'm trying to make a dimension style without the actual dimension line itself.  I'm trying to create a baseline type style without having to move my parts to 0,0,0.  Anyone know how to remove the dimension line in a style.
0 Me gusta
Responder
Soluciones aceptadas (1)
731 Vistas
8 Respuestas
Respuestas (8)
No aplicable
BTW.  I do have DIM LINE 1 and 2 turned OFF in properties.
0 Me gusta
imadHabash
your attached image Puzzled me some how ? any way .. you can suppress dimension lines from DDIM >> select your dim style and press modify >>  Lines tab  . is that really what you need or you're talking about Extension lines ?
Imad Habash
0 Me gusta
Kent1Cooper
The image is not clear to me, either.  Are you really talking about an extension line?
Kent Cooper, AIA
0 Me gusta
No aplicable
Thank you. Yes, the actual dimension line.  As you can see from the pic I was able to suppress the first extension line.  I’m trying to recreate a ordinate-type style without having to move all my objects to 0,0,0.  I’ve toggled on and off all the options in properties for the style with no results.
0 Me gusta
No aplicable
If you go into the dimstyle manager, you can suppress dim lines and / or extension lines there. See attached graphic.
Is this what you are trying to do?
0 Me gusta
No aplicable
I have both of those checked.
0 Me gusta
No aplicable
Odd, when I check those boxes, and exit the dialog box, existing dims using that style have the checked lines "disappear" and new ones created with those boxes checked don't have the lines in question.
Are you using any add-ins, custom startup routines, lisps, or other things that could alter the core functioning of ACAD?
What is your ACAD version and OS version? Are both up-to-date?
mine:
Win 10Pro 20H2 OS build 19042.906
AutoCAD 2021.1 (plain vanilla, no custom startups, autoload lisp, etc)
0 Me gusta
No aplicable
Solución aceptada
I think I found what I needed to.  It boiled down to me not really understanding the ordinate dimension style.  I just needed to move my origin to get the ordinate system to work.  Thanks all...
0 Me gusta
