Custom Command for several tasks (read below)
AlphabetABC
Message 1 of 13
AlphabetABC
Hi Everyone,
I have to repeat several steps to clean up Civil 3D drawing and make them readable on regular AutoCAD.
These drawings have Xrefs, sometimes a lot of them, and the process that I am following is this one:
  1. Copy each Xref  in a new folder
  2. Open the main drawing and change the path of each Xref to the new folder
  3. Open each Xref and start cleaning with:
    • Audit - y
    • Purge - a and Purge - r
    • Change - All - P - E - 0
  4. Qselect  - Line - Start / End Z to 0
  5. Qselect  - Polyline
  6. Qselect  - Arc
Now I need to make this process faster with a macro, and so far I was able to write the code till step 3:
^C^C_audit;y;-purge;a;*;n;-purge;r;*;n;_change;ALL;;P;E;0;;
Does anyone have any idea on how to continue?
Also, is it possible to create a command that I can start on the main drawing and automatically repeats these steps for each Xref?
Thank you in advance!
Replies (12)
Message 2 of 13
john.vellek
Hi marco.pedaletti,
While it looks like you have a good start on your script, have you considered using the Action Recorder to create a macro. It looks like it would be really well suited to this issue.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 3 of 13
TheCADnoob
Would you be able to Bind the xrefs and then purge and use something like exporttoautocad? or does it not clean them up enough.
CADnoob
Message 4 of 13
AlphabetABC
Unfortunately you are right, it does not clean it up enough.
Thank you
Message 5 of 13
john.vellek
Hi @AlphabetABC,
Do you have the Civil 3D Object Enabler installed? Perhaps that will make a difference in your process.
Please feel free to attach a sample drawing as well so I can take a look.
John Vellek
Message 6 of 13
AlphabetABC
Hi John,
Yes I have it, but my client probably does not.
Sorry but I'm not allow to attach the drawing.
Thank you,
Marco
Message 7 of 13
gdefilo
Hi marco.pedaletti,
have you considered the "flatten" command? It modifies the Z coordinate of entities floating in space.
You can find it in the Express Tools Menu.
It works on 2D entities and 3D polylines. But also blocks and hatches. It will not work on entities in blocks.
Hope this helps,
Giancarlo
Message 8 of 13
AlphabetABC
Hi Giancarlo,
That command sometimes creates problems, that's why we go through the steps mentioned before.
Thank you
Message 9 of 13
gdefilo
Well,
have a look at this, then:
http://forums.autodesk.com/t5/autocad-2010-2011-2012/how-to-globally-change-all-z-values-to-0/td-p/3...
Be sure to read all of the thread.
Hope this helps,
Giancarlo
Message 10 of 13
john.vellek
Hi @AlphabetABC,
I am checking back to see if my post or others helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 11 of 13
AlphabetABC
Hi John,
I am still trying to fix the method that I am currently using, I'm open to more options and I'm trying to use all the info received so far to make it better.
As soon as it works as I want, I'll create a new post.
Thank you,
Marco
Message 12 of 13
john.vellek
Thanks Marco,
Again, I would be happy to look at one of the subject files in order to offer you any other possible solutions.
John Vellek
Message 13 of 13
john.vellek
Hi @AlphabetABC,
In your first post, since you can't change Elevation in the Properties command, I think you would need a lisp routine to filter for Z values of each entity so you could set them to 0.
I used to have one called NEWZ.lsp  - I will try to see if I have a copy but there are likely more modern and better ones in the Customization forum.
John Vellek
