Cursor Problems
Cursor Problems
stevek
Message 1 of 10
Cursor Problems
stevek
Hey all,
Scenario: I got a new workstation with windows 10/Autocad 2019(full).  Previous workstation had Windows 7/ Autocad 2013(LT) I have a Corsair Scimitar Pro mouse that I moved to the new workstation and the cross-hairs are "jumpy" but only with the corsair mouse. If I use other mouses(mice?) they are very fluid. My corsair mouse has a bunch of buttons and is customized with all my commands, so I would prefer to use that one. This was not a problem with Autocad Lt 2013 on my old workstation.
My hardware should be more than sufficient to handle any of this.  Im not sure if its the mouse software, or the autocad software. Please help me figure out where to start to resolve this issue.
Thanks in advance!
Replies (9)
Message 2 of 10
TheCADnoob
Im not too familiar with that device, though i have a few suggestions
Have you tried cleaning the sensor with compressed air?
Have you tried changing the mouse surface (mouse pad, book, desk etc)?
Have you updated the Driver?
Have you tried checking to see if there is a firmware update?
Have you tried dropping the DPI or the dropping the polling rate?
Have you tried switching to a different USB port Perhaps changing from a USB 2 to something else)?
CADnoob
Message 3 of 10
stevek
  Its only jumpy when cursor is in drafting area
 It has been updated
 it has been updated
I Decreased DPI, but do not know how to adjust polling
Yes
~Thank you for your help
Message 4 of 10
TheCADnoob
Did you happen to install Corsair link with your mouse software?
CADnoob
Message 5 of 10
stevek
I installed the iCUE software that is required for the mouse to be
customized.
Message 6 of 10
TheCADnoob
This is well outside of my wheel house but from what i have read iCUE is meant to replace CUE and LINK. Im not sure if that has happened or what the status is on all of that or if its a group install kind of thing. I have read that others have experience Link being a resource drain and had luck gaining smooth operation with link not running. can you open your system resource while trying to use CAD and the mouse and see if something is using a lot of resources. Or perhaps see if link was installed and uninstall it.
CADnoob
Message 7 of 10
Snip931
I have the same issue as you using a Logitech G502 mouse with Autocad 2019. It only lags in model space but not mousing over menus. If i use my old Logitech G5 mouse the issue doesn't happen.
Tried -
Ive tried different USB ports - no change
I removed the logitech mouse driver & software and let W10 install its generic driver - no change
Not tried -
Changing DPI on mouse or in windows mouse settings.
Changing polling rate via Logitech driver/software.
Could this be an issue with a feature gaming mice have in common?
Both mice have current/updated drivers & Firmware
W10 Pro  Build 17134
Autocad 2019.1  P.103.0.0
Message 8 of 10
Snip931
Tried -
Not tried -
W10 Pro  Build 17134
I believe our solution may be the same as this post i found here.
https://forums.autodesk.com/t5/civil-3d-forum/fresh-2019-civil-3d-cursor-lag/td-p/7936662
Looks like a DPI/Polling rate issue with higher end gaming mice, Scroll down to the solution.
Message 9 of 10
MB87
I also have the same problem, I have several gaming mice, I've tried Logitech and Razer, they are the ones I usually use to work. I found out that the polling rate is at the source of the problem. if you put the mouse at 125hz the slow cursor problem disappears or reduces a lot. if I set it to 1000hz, I notice the cursor slow, for example when I draw a very long poyline. i don't think autodesk is aware of these types of questions.
Message 10 of 10
pendean
Community Legend
Community Legend
>>>...i don't think autodesk is aware of these types of questions...<<<
@MB87 You can change that perception here yourself https://www.autodesk.com/company/contact-us/product-feedback
HTH
