Cursor Lags When Drawing a Line
22477816
Observer
22477816
Observer
Observer
Hi all,
AutoCAD is usually not an issue for me. However when I opened my laptop today some setting has changed. When i move the mouse/cursor it moves compeltely smooth and normal. When i click on the line tool it does not smoothly transition across the grid, but instead it jumps and lags.
Why is this happening and how do i fix it?
0 Me gusta
Responder
Soluciones aceptadas (1)
4.147 Vistas
4 Respuestas
Respuestas (4)
pendean
Community Legend
Community Legend
Is the problem in the one file, or ALL files?
Do you just need to fully shut down and restart your laptop?
What change with our laptop today? something did, or something at the location of the file did.
0 Me gusta
22477816
Observer
Observer
Happens in all files. AutoCAD froze twice today which has never happened before - but nothing other than this happened.
0 Me gusta
pendean
Community Legend
Community Legend
Dig a little deeper: sounds like an update or a removed app or a system change is in play, software programs don't just break on their own without external effect.
Assuming the problems are not your files: where do you store them and how does the laptop reach them?
0 Me gusta
Alfred.NESWADBA
Solución aceptada
I have seen that after an operating system update the graphic card was not recognized any more or is not compatible with the update. First verification for that:
  • start command _GRAPHICSCONFIG
  • verify if the correct graphic card is used by AutoCAD
  • turn off hardware acceleration in that dialog and see if something changes
  • in the same dialog try the button (bottom) to "Restore Defaults"
Restarting the workstation after these modifications might help too.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
