Cursor Jumping in 2022
martins
martins
I have the same issue. Very annoying. Have tried all the above suggestions but still jumping. Same issue jumps down about 280° until the mouse is moved again.
Autocad 2022
NVIDIA GeForce GTX 1080
Will be going back to 2021
[This post has been split from the 2022 Jumpy Cursor thread for clarity by cheryl.bucK]
pendean
Community Legend
Community Legend
F9 SNAP turned on?
Have you installed the 2022.1 Update yet? If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT2022: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables: if still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort.
martins
Yes I have tried all of those suggestions (I think) from the other thread.  Thanks for those. I thought my problem was similar to the other thread where I posted it but it got moved to here. From what I read in the other post, it will be fixed in the next update? I already had updated to 2022.1
martins
I'm back using 2021 now. I'll try again with 2022 soon to see if it still doing it..
