Cursor disappears when changing layouts
I have a small annoyance on 2015 and am curious if other have had it happen. It is more likely to happen in a drawing with many layout tabs. Typically, when switching from Model to a layout tab or from one layout tab to another, the cursor will be the typical crosshairs when you move the cursor into the drawing area. Click on a tab, move the cursor above the tab and it will be crosshairs with the open box in the middle. Every so often (maybe 25% of the time), I don't get the crosshairs. Instead, it stays as the typical mouse arrow that it becomes when you hover over a layout tab and I need to click once in the drawing area to get rid of it (escape doesn't get rid of it), at which point it acts like I tried to select something. It can happen going from a layout tab to Model space also. Seems to possibly have something to do with regenerating the layout because I did notice that if I click on a tab once, get the odd arrow, click on a different tab and then go back to the first tab, that first tab now has the crosshairs instead of the arrow. I tried all 3 "Layout Regen Options" and nothing makes a difference.
Anyone else experience this?
