Cumulative Area
Cumulative Area
mehsan
Cumulative Area
mehsan
Greetings
If i am selecting one Rectangle i am getting the area but if select another one it is giving me "Varies" in the properties , till yesterday it was working but today it is not working.
imadHabash
Cumulative area in properties palette exist for Hatch objects  NOT for rectangles or polylines .
Imad Habash
parkr4st
search web       autocad cumulative area lsp
take your choice
mehsan
I use to select two days before two rectangle together and i was getting the cumulative area , but suddenly i do not know what happened.
vinodkl
Hi @mehsan
That would be the case when you select two rectangles of the same length, but it is not showing the cumulative area it's showing the area of the individual rectangle as both are of the same length.
To get the cumulative area of the rectangle use the attached lisp 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
tboehler
have you tried the AREA command?  "AREA", "A" (for Add), "O" (for objects).  You can also subtract objects.
Other commands that may help with your process - creating boundaries.
Lineworkshrinkwrap
Bpoly
Kent1Cooper
@vinodkl wrote:
....That would be the case when you select two rectangles of the same length, but it is not showing the cumulative area it's showing the area of the individual rectangle as both are of the same length.
That should be "of the same area" rather than "of the same length," in both instances.  Two rectangles can be of the same length without being of the same area, in which case Properties would show a number in the Length slot [assuming you mean the length of the perimeter], but would list the Area as "Varies."
Kent Cooper, AIA
