CTB STYLE PROBLEM
CTB STYLE PROBLEM
CTB STYLE PROBLEM
I AM USING A CUSTOM CTB STYLE IN DRAWING.. BUT WHEN OPEN THIS DRAWING IN OTHER PC IT SAID PLOT STYLE MISSING.. HOW CAN I FIXED THE CTB STYLE??
pbejse
Look into CONVERTPSTYLES and/or CONVERTCTB
Thanks.... But it not working.. I convert CTB to STB style.. Then save the drawing & open it in another computer.. But it show CTB style is missing.
TomBeauford
Just copy the CTB file to the other PC's Plot Styles folder (Plot Styles Manager…).
Plot Styles aren't saved in the drawing, they're referenced.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Valentin_CAD
@Anonymous ,
To avoid missing or having different CTB on many computers, consider placing all your CTB in a network location and then adding that location to your profile OPTION setting.
Sample:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Alfred.NESWADBA
If parts of your projects are missing you have add this parts to make your project complete.
If a CTB file is part of your project and you send the data to someone else or open this on a different workstation, you can't just copy the DWG and that's it.
Best to get all referenced data together is to run command _ETRANSMIT inside AutoCAD, then you get the DWG and all referenced files like XRef, images, CTB/STB, ... into one ZIP and that contains everything necessary to continue the work.
Details to _ETRANSMIT: >>>click<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
