CTB file confusion
dbanaszak
CTB file confusion
dbanaszak
I'm trying to modify the pens from 250 on up by using the same settings that are in the ACAD.CTB file. I'm trying to get the same shaded values for grey scale solid fills. My NEW.CTB file was copied from a project CTB file which I modified to have the same values for pens 250-255. Unfortunately, they don't plot at all in my drawing. Any ideas? Thanx
0 Me gusta
Responder
Soluciones aceptadas (2)
1.050 Vistas
10 Respuestas
Respuestas (10)
pendean
Community Legend
Community Legend
You're going to have to share your custom CTB and a sample DWG file where it fails here for review: can you do that now?
0 Me gusta
paullimapa
Share your dwg as well
Paul Li
IT Specialist
@The Office
0 Me gusta
dbanaszak
I don't seem to be able to drag and drop the CTB file.
0 Me gusta
paullimapa
zip the ctb along with sample dwg and post that
Zip and unzip files - Microsoft Support
Paul Li
IT Specialist
@The Office
0 Me gusta
dbanaszak
See attached.
0 Me gusta
pendean
Community Legend
Community Legend
@dbanaszak wrote:
See attached.
And the DWG file? Or at least a relevant portion, titleblock/client info is not needed (even though it is there in the PDF).
0 Me gusta
dbanaszak
D'oh! Grabbed the wrong file. Sorry.
0 Me gusta
cadffm
Solución aceptada
your PDF is not the result of plot C3.0 with CivilShade.ctb
Plotting with this .ctb will hide ALL Objects with color 250-255
because they are set to print 0%
So it isn't set to the same as the original acad.ctb (also Greyscale property is different for 253)
Sebastian
0 Me gusta
cadffm
offtopic
Please, Next time: Set the sample Layout current and set pagesetup proper to what you are talking about - and what you used for the sample plot/pdf, many thanks from all helpers :cara_que_sonríe_con_ojos_sonrientes:
edit
Have you managed to solve this problem now or do you still need support? @dbanaszak
Sebastian
0 Me gusta
dbanaszak
Solución aceptada
I don't know how I overlooked that setting, but thank you for pointing it out.
0 Me gusta
