Crosshair Pline
Crosshair Pline
No aplicable
Is there a setting to enlarge the temporary starting point crosshair when drawing a pline?
0 Me gusta
Responder
468 Vistas
8 Respuestas
Respuestas (8)
tcorey
A screenshot would explain better what you're trying to do.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
0 Me gusta
imadHabash
you can control the size from OPTIONS >> Display tab.
Imad Habash
0 Me gusta
john.vellek
Hi @Anonymous,
There is no built in feature of AutoCAD that will only increase the cursor or crosshair  size when drawing a pline. You could perhaps write/find a macro or lisp routine that would change the cursorsize before the command and then reset it after you complete the command. Another option might be to find Windows add-in to let you do this.
John Vellek
No aplicable
Please see attached for screenshot
0 Me gusta
No aplicable
thanks that's what i guessed seeing how it is very insignificant feature to have additional options for.
0 Me gusta
Kent1Cooper
That appears to be a BLIP [though the one being green  is something I haven't seen before -- maybe a version-dependent thing].  Whether  Blips appear or not is controlled by the BLIPMODE System Variable, which you can also set via .BLIPMODE [note the preceding period/decimal] as a command, but I haven't ever seen a way to set the size  of them.  Your Windows screen resolution settings may affect it.
Kent Cooper, AIA
john.vellek
Hi @Anonymous,
Is BLIPMODE what you were looking for? If so, please mark @Kent1Cooper's post as the solution. If not, please give me more detail for which you are looking.
John Vellek
0 Me gusta
Vinayv4v
In addition to BLIPMODE If you would like to get a permanent point you could turn on the variable
APBOX <1>
and increase its size with the variable APERTURE <1 to 50>
Cheers,
Vinay Vijayakumaran
0 Me gusta
