Sir
As I look at the comments I see " quicker than what ? "
We see " what about the + sign click and create ? "
We see " no video ? "
Ken posted a well structure comment I feel is good solution to my poor description and title I gave.
Hence selected as solution to the confusion there seems to be .
Second solution is the link to the screen cast for some reason did not share with the original post.
Hence clears up the no video comment.
Interesting tip I found and wanted to share, as I do see I'm partaking in the knowledge network.
I do however found , maybe screen cast is not for forum question ?
As a veteran that I can clearly see you are.
Can you direct where one can post screen cast like this.
The goal essentially is to share and learn with constructive input, as this is AutoCAD and there is always more than one way. In this way of course whit good input I can even learn more, might be next girl or guy can think what Rob said actually works and is good might be even more convenient for them to use ?
I might completely miss understand the whole Knowledge network ?
Yes I apologize sir for taking part in replying in your fruitful conversation as this would have no end.
Have a good one sir and looking forward to seeing your input in the next Tutor Tuesday ^^
