I was hoping someone could help? I was tasked with creating a linetype for a silt fence. I first drew a few items that I later turned into objects and made several attempts to try to find a way to create a linetype with text inside a circle and the the circle to be not transparent. I did create the linetype, however, the circle was transparent and I needed what was below to be not visible. I was able to achieve this using the objects I created and the using the multiline tool and setting the offset to zero but it did not work as well as I thought it would. Also, the object hatch I created in the attached dwg file I used color 255 and set in the ctb file to use object color to have a white background when plotted.
What I need to know is if its possible to do this with a single line linetype?
Using AutoCAD 2015 on windows 8
I very well may be in the wrong forum, please forgive, its my first time posting something.
