Creating an XLINE from Polyline Endpoint Problem
Message 1 of 10
Hi all. First off thanks for taking the time to read this; all help is much appreciated.
So my problem is with the XLINE command in AutoCAD LT 2017. When I go to create an XLINE and use a polyline endpoint as my first point I get these weird green dashed lines across my screen. See the picture.  Now, I can successfully create the XLINE if I use polar tracking to pick a point along the line I want and then use a polyline endpoint as my second point.
This is a very weird issue that I haven't experienced before in any version of AutoCAD and was hoping someone had a fix for it!
Replies (9)
Message 2 of 10
Alfred.NESWADBA
welcome @Anonymous!
I guess you mean the object tracking (which I see as a big feature, and never as weird, to be honest I could not work without 😉 ).
You can turn object tracking using <F11> or in the dialog for object snaps as shown here:
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
I certainly agree that Object Tracking is an amazing feature, but if you look closely at the picture I don't have object tracking enabled... I thought that was the issue as well but toggled it off to see if that was in fact the case.
Any other ideas?!
Message 4 of 10
Alfred.NESWADBA
sorry, in that case it's Polar-Tracking or <F10>
- alfred -
Alfred NESWADBA
Message 5 of 10
Sorry unfortunately that doesn't fix the issue.
Message 6 of 10
Alfred.NESWADBA
well, can you please show a screencast from what you are exactly doing while all tracking-options are turned off?
If not already installed you can download and install (and use) Autodesk Screencast for free >>>click<<<.
Maybe we see what's happening when we see what you are exactly doing with commands and settings.
- alfred -
Alfred NESWADBA
Message 7 of 10
The screencast is below.
Message 8 of 10
Alfred.NESWADBA
Sorry, no screencast here ...
- alfred -
Alfred NESWADBA
Message 9 of 10
Message 10 of 10
Alfred.NESWADBA
if I look to your video I can see that as long as <F10> and <F11> are off, there are no green lines, ... do you see any while you are working? In that case try the same again with hardware acceleration OFF (command _GRAPHICSCONFIG).
- alfred -
Alfred NESWADBA
